Hard start and rough idle
Picked up a 1991 4x4 4.0 long bed a few months ago. Needed a new battery and would crank but wouldn’t start. Changed distributor, ignition coil, wires, plugs, and CPS. Now it has a hard start and a little rough idle. I’ve done the fuel filter too. There’s a weird DIY vacuum setup so idk if that’s affecting it. It starts everytime but I’m afraid I’ll wear out the starter. If I start it and then turn it off and turn it back on it starts up right away. Maybe fuel pressure or weak spark?
If you can drive it for a bit, or even just sit idling, you might be able to get some codes off of it. The CEL will only be on during an active fault, but codes will be retained for 50 key cycles.
I wouldn’t be concerned about burning out a starter. They’re usually good for a few thousand starts. What really kills them is low voltage during cranking due to a weak battery or poor connections.
