70barracuda Posted January 11, 2023 Posted January 11, 2023 I have a 2wd ax15 in unknown condition and a pretty good ax5 transmission with the external slave setup. $75 for the ax15 and $50 for the ax5. Also have a 2wd ax15 with a Chevy adapter plate. Used it for an ls swap. Has bellhousing, adapter plate, mount, and slave cylinder for it. Trans shifted good. Asking $500 for the whole kit. Local pickup in central NJ only.
Oizarod115 Posted February 2, 2023 Posted February 2, 2023 I need an XJ/MJ AX15 shifter, if your transmissions are from XJ/MJ are you interested in selling a shifter separate? Any chance you have the mount plate that bolts between the transmission and rubber mount? Would be interested in that as well.
Archived
