johnny quest Posted April 4, 2006 Share Posted April 4, 2006 how easy is it to convert an MJ over to front springs instead of coils?? what springs work best?? should i just work with the coils anyway?? Link to comment Share on other sites More sharing options...
GirsMJ86 Posted April 4, 2006 Share Posted April 4, 2006 it would be easiest/best to stick with your coils. there is really no reason to go to leafs bcuz u can make coils flex/hold just as much if thats y you are mainly thinkin bout doin this. unless there is sumthin i don't know about. alex Link to comment Share on other sites More sharing options...
pingpong Posted April 4, 2006 Share Posted April 4, 2006 Is this a trick question? Obviously if you are asking us this question you have not researched it very much. Most ppl use wagoneer springs or custom leafs up front. The only real issue is steering in my opinion, and considering the overall weakness of the D30, an axle upgrade would be inorder. A d44 with flat top knuckles would be my choice. The other issue would be, maing sure the "frame" is beefed up enough at the spring mounting points. Also pinion angle might be an issue if using a LP axle. search pirate and naxja for more info Link to comment Share on other sites More sharing options...
jeepmj_tj Posted April 4, 2006 Share Posted April 4, 2006 i've done it, works great, drives good on the hwy as well. I'm using a waggy d44 with cross over steering. 2 1/2" lift yj springs SOA with an additional 2 1/2" main leaf as an addaleaf. let me know if you have any other questions. joe Link to comment Share on other sites More sharing options...
