Proportioning valves: abs v non-abs
Moving forward with a booster upgrade and swapping to an XJ prop valve. The one I got with the booster only has 4 ports: 2 in and 2 out. The port in the back is plugged.
Normally, the valve should have 5 ports: 2 in, 1 for RF, 1 for LF, and 1 for the rear.
Since the abs controls each wheel it stands to reason it only needs 2 inputs: 1 front, 1 rear.
Am I correct? Do I have the wrong valve?
EDIT:
I may have found my answer.
https://www.jeepforum.com/threads/proportioning-valve.787040/
The LSV was deleted years ago.
I picked up two prop valves at the JY yesterday. One from an XJ with rear drums. The other was from a ZJ with disc ABS - only one line for front brakes. I watch a YouTube video on converting this to handle non-ABS.
I will run one new line to the rear eliminating both old lines.
