Rokhound Posted December 9, 2007 Share Posted December 9, 2007 Ok guys I am not a master fabricator so I have been doing some thinking (this could be bad) and digging around on the net and there is a bunch of premade stuff out there to do a 3 link with a panhard. So I thought I would put my thought down and see what you guys think and maybe some one could add or tell me what I should do different. First off trail-gear makes a 3 link for a Toyota I think I could make it work on a MJ. So that is the first link. http://www.trail-gear.com/trail-link.html Or I could buy the parts one at a time I really like there Panhard / Upper Link Combo Mount http://www.trail-gear.com/trail-link-parts.html Now for my coil spring I was thinking some thing like this For the lower part to the keep them to the axle http://ballisticfabrication.3dcartstore ... -1179.html And for the upper part to hold them to the frame http://ballisticfabrication.3dcartstore ... -1478.html Now for the lower control arm mount to the frame I was thinking of using these http://polyperformance.com/shop/product ... 158&page=1 And here is a link to pirate where a guy has put one on a tacoma that show the set up it look very simple: http://www.pirate4x4.com/forum/showthre ... ght=3+link What are your thoughts? Link to comment Share on other sites More sharing options...
MF Steve! Posted December 9, 2007 Share Posted December 9, 2007 As for the coil spring perches, look at the Ballistic Fabrication 4 in 1 spring, shock, track bar and control arm mount. They're $40 each, but you're getting everything all in one. Even if you didn't use the shock mount, as it is designed for a front axle, incorporating everything into one strong bracket wouldn't be a bad idea. Link to comment Share on other sites More sharing options...
TNT Posted December 9, 2007 Share Posted December 9, 2007 I have been planning a 4 link for the rear probably next winters project. For spring mounts I plan on cutting off some from a XJ or a MJ axle and cutting off the upper mounts the front uses. Stock XJ or MJ springs should be about right. For joints the 3" Ballistic Fab flex joints with 1.25" studs are planned and some 2.5" studded flex joints would be used. I'll cut my own mounts for the control arms and build it all myself. I like to fab as much as I like to wheel. I take pride in building it myself. Your plan seems like a good one. The 3 link should work well. I'm relocating my fuel tank so I'll have room for a 4 link double triangulated setup. Link to comment Share on other sites More sharing options...
Rokhound Posted December 9, 2007 Author Share Posted December 9, 2007 O I would love to build my own stuff but I don't have the shop,tools or skills to do it. So that is why I am leaning this way. Link to comment Share on other sites More sharing options...
MF Steve! Posted December 9, 2007 Share Posted December 9, 2007 Right there w/ you TNT. Nothin like getting in the shop, firing up the welders and plasma and goin to town. Now if only I could quit blowin my money on everything else, and get my front 4-link fabbed up and bolted in! Link to comment Share on other sites More sharing options...
feerocknok Posted December 9, 2007 Share Posted December 9, 2007 5 posts down is my supply list: http://www.comancheclub.com/forums/view ... hp?p=70169 I blew my warranteed motor and they're paying me to put the new motor in, so I'm using that money to do my links in the spring. I wouldn't by a Yota specific link set-up with the frame dimensions being So different. Link to comment Share on other sites More sharing options...
Rokhound Posted December 9, 2007 Author Share Posted December 9, 2007 Thanks for the info I see that I am not the only one that has thought about buying all the parts that are need to build a 3 link. I do really like the lower link and coil mounts I think it would keep it simple. I have a D60 for the rear that I am thinking about shaving I no over kill but I think that is what I am after. I want to run something like 36 to 38 locked front and rear. Again this may never happen this is what happens when the weather gets could and I can’t play with my truck. Link to comment Share on other sites More sharing options...
