jtdesigns Posted December 8, 2007 Share Posted December 8, 2007 Wouldn't this driveshaft bind up? Image Not Found plausible ???? Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 8, 2007 Share Posted December 8, 2007 Wouldn't this driveshaft bind up? Image Not Found plausible ???? no, that's got a pillow block. if you look farther to the left you'll see the driveshaft goes through a bearing assembly to another driveshaft that connects to the transmission. Link to comment Share on other sites More sharing options...
Badger Posted December 8, 2007 Share Posted December 8, 2007 granted the slip yoke should be on the lower half or second shaft technically it would work.not saying thats how i would have done it but it would work.normally you would want to have a yoke directly after the pillow block this way you would have a long drive shaft to the axle itself. Link to comment Share on other sites More sharing options...
