Front leafs. which ones to use?
I am doing a leaf spring conversion and plan on using the lower control arm frame bracket. I tried an XJ leaf and the center pin location seems to be a good bit off, a CJ7 front leaf looks like it would be a perfect match but I want a longer spring than the CJ spring. Any ideas?
I plan on front shackles and they will mount to the bumper which will be directly in front of the factory crossmember.
Maybe I should ditch the idea of using the LCA bracket and make a new bracket for the spring?
