Pictures needed of 4wd linkage for 86
I need a picture of the 4wd linkage and brackets for a 1986 Comanche with a 904 automatic and 207 transfer case. I think it don’t matter if it’s a 4cyl or v6. I am in the middle of converting mine to 4wd and missing a bracket, I think I can fab but need to see if my thoughts are correct
do you have the body side bracket?  do you have the transmission side bracket?  can't say for sure, but I gotta think that the body side bracket is the same across the board.  the transmission side will vary.  I made the trans side for my 00 AX-15 swap out of a straight piece of 3/16" flatbar stock.
you should be able to use the Azzy linkage too and skip the brackets altogether.  :L:
https://www.azzysdesignworks.com/shop/p/xj-linkage-mopar
I have the body side bracket but amc was nice enough not to put the holes in the transmission tunnel for me. I'm missing the transmission bracket.  I saw the Azzy bracket  but it did not mention being able to use with the 207
