fiatslug87 Posted July 31, 2022 Share Posted July 31, 2022 on CarGurus in Tacoma, WA asking $11,999 Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 7, 2022 Share Posted August 7, 2022 *X1 TRIM STYLE X1 - CLOTH BENCH -SA Charcoal 171 Zone 71-Los Angeles 1AA U.S. Dealer Retail 4AF 5AM 5KM ADA Light Group ADB Protection Group ADH Heavy Duty Electrical Group ALM APA Monotone Paint BA1 100 AMP ALTERNATOR BCY BATTERY, 58-475 CC BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CLA Front Floor Mats CSR Passenger Assist Handles DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHN Command-Trac Part Time 4WD System DHT Shift-on-the-Fly,P/Time T/Case DJH 230MM Front Axle DMD 3.55 Rear Axle Ratio DRK Dana 44/226MM Rear Axle DSA Anti-Spin Differential Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEC Front Left Side Sliding Window GNA Rear View Day/Night Mirror GNB Driver Side Illuminated Sun Visor GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBD BEZEL-I/PANEL CLUSTER - BRIGHT JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB K2X STRIPE/BADGE/MOLDING/COLOR K3D STRIPE/BADGE/MOLDING/COLOR KKE LAF Seat Belt Alert-Driver Seat only LAJ Headlamps On Warning Chimes LBB Courtesy Lamps LBC Glove Box Lamp LBD Ash Tray Lamp LBE Ambient Light LCJ DOME/READING LAMP B-PILLAR LDH U/Hood, Removable/Rechargeable Lamp LHD Headlamp Off Time Delay LMA Halogen Headlamps LPE Cargo Lamp MB1 Black Front Bumper MBJ Black Bumper MCA MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver MMP MOLDING - DOOR EDGE GUARDS NAE California Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF5 Fuel Tank - 23 Gallon PS3 DOVER GREY MET CL CT PRIMARY PAINT - HS3 QS3 DOVER GREY MET C C SECONDARY PAINT - HS3 RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Steering SCE Wrap Steering Wheel SFB Front Heavy Duty Shock Absorbers SGB Rear Heavy Duty Shock Absorbers SUA Tilt Steering Column TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TRP 225/70R19.5G All Pos Traction Tires WJD 15X7.0 Styled Steel Wheels XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z58 Left Front Spring Group Viii Z5B Payload Rating - 1800# Z78 Right Front Spring Group VIII Build date 9/25/88 Body code JM62 Sold by PASADENA JEEP EAGLE INC, PASADENA CA Link to comment Share on other sites More sharing options...
