cpacker208 Posted July 8, 2022 Share Posted July 8, 2022 Lost my brake lights, turn signals, and hazards in the rear. Turn signals and hazards still work in the front and run lights also still work. I’ve checked the bulbs, fuses, the rear connector, the grounds looked good, and cleaned out my fuse box’s connector too. My stock taillights currently aren’t wired up just have two trailer lights that worked before. Any help is greatly appreciated! Link to comment Share on other sites More sharing options...
Ωhm Posted July 8, 2022 Share Posted July 8, 2022 49 minutes ago, cpacker208 said: and run lights also still work Is that for both the front and rear running lights? If front only, double check the grounds on those two trailer light assemblies. Ground through chassis or wired to ground. Link to comment Share on other sites More sharing options...
cpacker208 Posted July 8, 2022 Author Share Posted July 8, 2022 2 hours ago, Ωhm said: Is that for both the front and rear running lights? If front only, double check the grounds on those two trailer light assemblies. Ground through chassis or wired to ground. I have running lights in front and rear and ground through chassis Link to comment Share on other sites More sharing options...
cpacker208 Posted July 8, 2022 Author Share Posted July 8, 2022 Update: I just started pulling tape off some of the wire bundles and now i’m starting to wonder how they ever worked. Link to comment Share on other sites More sharing options...
Eagle Posted July 8, 2022 Share Posted July 8, 2022 Link to comment Share on other sites More sharing options...
