Renix connector locations
Connector Number Locations
Connector C100: Left Of Master Cylinder On Dash
Connector C101: Above Master Cylinder
Connector C102: Behind LH Headlamp
Connector C103: Next To RH Shock Tower
Connector C104: Next To RH Shock Tower
Connector C105: Behind Battery
Connector C106: Next To RH Shock Tower
Connector C107: Next To RH Shock Tower
Connector C108: In Front Of Washer Bottle
Connector C109: Next To RH Shock Tower
Connector C110: RH Rear Of Rocker Cover
Connector C111: RH Rear Of Rocker Cover
Connector C112: RH Rear Of Rocker Cover
Connector C113: RH Rear Of Rocker Cover
Connector C114: RH Rear Of Rocker Cover
Connector C115: Under Dash To Right Of Steering
Column
Connector C116: Above Master Cylinder
Connector C117: In Front Of Washer Bottle
Connector C118: Under LH Side Of I/P Behind Kick
Panel
Connector C119: Under LH Side Of I/P Behind
Kick Panel
Connector C120: Behind A/C Mode Select Switch
Connector C121: Under LH Side Of I/P Behind
Kick Panel
Connector C122: Under RH Side Of I/P Behind
Kick Panel
Connector C123: Under RH Side Of I/P Behind
Kick Panel
Connector C124: Under LH Side Of I/P Behind
Kick Panel
Connector C125: Under LH Side Of I/P At Kick
Panel
Connector C126: Behind LH Rear Inner Fender
Panel
Connector C127: Behind LH Rear Inner Fender
Panel
Connector C128: Under RH Side Of I/P At Kick
Panel
Connector C129: Behind RH Kick Panel
Connector C130: Under LH Side Of I/P At Kick
Panel
Connector C131: Under LH Side Of I/P At Kick
Panel
Connector C132: Under LH Side Of I/P At Kick
Panel
Connector C133: Under LH Side Of I/P At Kick
Panel
Connector C134: Under RH Side Of I/P At Kick
Panel
Connector C135: Under RH Side Of I/P At Kick
Panel
Connector C136: Under RH Side Of I/P At Kick
Panel
Connector C137: Under RH Side Of I/P At Kick
Panel
Connector C138: Under Front Seat
Connector C139: LH Rear Inner Fender Panel
Connector C140: Behind LH Rear Inner Fender
Panel
Connector C141: Behind LH Rear Inner Fender
Panel
Connector C142: Behind LH Rear Inner Fender
Panel
Connector C143: Behind LH Rear Inner Fender
Panel
Connector C144: Behind LH Rear Inner Fender
Panel
Connector C145: Behind LH Rear Inner Fender
Panel
Connector C146: Behind LH Rear Inner Fender
Panel
Connector C147: Behind RH Rear Inner Fender
Panel
Connector C148: In Console
Connector C149: In LH Side Of Liftgate
Connector C150: In LH Side Of Liftgate
Connector C151: In LH Side Of Liftgate
Connector C152: Behind A/C Mode Switch
Connector C153: Near Cargo Lamp
Connector C154: Above Transfer Case
Connector C155: Behind RH Kick Panel
Connector C156: Under I/P On Steering Column
Connector C157: Below LH Side Of I/P Above
Parking Brake
Connector C158: Rear Center Of Cab Under
Carpet
Connector C159: Behind LH Rear Tail Lamp
Assembly
Connector C160: Behind LH Rear Inner Fender
Panel
Connector C161: At Rear Bumper
Connector C162: At Rear Bumper
Connector C168: Top Of Washer Bottle
Connector C169: Below Washer Bottle
Connector C170: LH Side Of Cowl Panel Grille
Connector C171: To Left Of Steering Column
Connector C172: In Driver's Seatbelt Buckle
Connector C173: Under RH Front Seat
Connector C174: Under LH Front Seat
Connector C175: Behind RH Headlamp
Connector C176: On Left Of Steering Column
Connector C177: LH Side Of I/P Next To Light
Switch
Connector C178: LH Side Of I/P Next To Light
Switch
Connector C179: Behind RH Side Of I/P
Connector C180: At Speaker
Connector C181: At Speaker
Connector C182: At Speaker
Connector C183: At Speaker
Connector C184: At Speaker
Connector C185: At Speaker
Connector C186: In Center Of I/P
Connector C187: In Center Of I/P
Connector C188: Below I/P Behind Defogger
Relay
Connector C189: In LH Side Of Console
Connector C190: Under LH Side Of I/P At Kick
Panel
Connector C191: Under RH Side Of I/P At Kick
Panel
Connector C192: Taped To Harness Above Fuse
Block
Connector C193: Behind Center Of I/P Below
Lighter
Connector C194: On I/P To Right Of Steering
Column
Connector C195: Below Washer Bottle
Connector C196: Center Of Liftgate
Connector C197: Center Of Liftgate
Connector C198: On I/P To Right Of Steering
Column
Connector C199: In Driver's Seatbelt Buckle
Connector C200: Under I/P To Right Of Steering
Column
COMANCHE
Connector C100: In LH Dash Panel Forward Of
Fuse Panel
Connector C101: Behind LH Headlamps
Connector C103: RH Side Rear Of Engine
Connector C108: Near A/C Compressor
Connector C109 (Diesel Engine): Near Lower
Center RH Inner Fender Panel
Connector C109 (Gasoline Engine): Near A/C
Compressor
Connector C112: Behind Battery Near Starter
Relay
Connector C115: Taped To Engine Harness
Behind Cruise Servo
Connector C119: LH Side Of Engine Near Glow
Plugs
Connector C120: LH Side Of Engine Near Glow
Plugs
Connector C200: Under LH Side Of I/P Behind LH
Kick Panel
Connector C202: Under LH Side Of I/P Behind LH
Kick Panel
Connector C203: Under LH Side Of I/P Near
Ignition Switch
Connector C204: Behind Mode Select Switch
Connector C205: Under RH Side Of I/P Behind
Kick Panel
Connector C207: Under I/P Above Brake Pedal On
Steering Column
Connector C209: Under RH Side Of I/P At Kick
Panel
Connector C210: Near RH Door Jamb Switch
Connector C211: To Left Of Steering Column
Connector C314: In RH Side Of Liftgate
Connector C315: In LH Side Of Liftgate
Connector C402: Under LH Side Of I/P At Kick
Panel
Connector C404: Under RH Side Of I/P At Kick
Panel
