WranglerMangler Posted June 4, 2022 Posted June 4, 2022 Saved from the junkyard. Bought it out of the yard before a single part was taken off luckily. $800 only one little dent on bed below the tail light. Bought as a Blue pioneer 1991, 4.0 HO, 2wd, SWB, D35, nothing special Converted to a 4wd AX15, 231J, D44 F&R Detroit lockers, Custom Radius arm, plated the frame from front bumper bolts back to the front of the rear spring hangers. Still a work in progress. No pictures yet.
eaglescout526 Posted June 8, 2022 Posted June 8, 2022 *C1 TRIM STYLE C1 - BENCH SEAT -SA CHARCOAL 172 Zone 72-Portland 1AA U.S. Dealer Retail 3V2 Customer Preferred Discount 5KM AMES Department Stores ALM APA Monotone Paint ARL BAP 75 Amp Alternator BCX Maint. Free Battery BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DMM 3.07 Rear Axle Ratio DRJ Dana 35 Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K27 Do Not Use K2B STRIPE/BADGE/MOLDING/COLOR K3L STRIPE/BADGE/MOLDING/COLOR KKS STRIPE/BADGE/MOLDING/COLOR KWS STRIPE/BADGE/MOLDING/COLOR LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFF Black Grille MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PB8 MIDNIGHT BLUE MET CC PRI PNT - HB8 QB8 SECONDARY PAINT RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Steering SCE Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TBB Full Size Spare Tire TBM Tire Carrier Winch TMW Tires TZH Michelin Brand Tires WJN 15" Aluminum Wheels WLZ All Aluminum Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z58 Left Front Spring Group Viii Z77 Right Front Spring Group VII Build date 8/27/90 Body code TL61 Sold by RENTON JEEP-EAGLE, RENTON WA
