1JTWW6672GT222921
Agreen
1986 Jeep Comanche
2.8 AX5 2wd LWB
Build date: Illegible.  Seems like it has faded off.
Current Location: Near Augusta,GA
Status: Just bought it 24 Apr, 2022. P.O. said it hadn't ran in 5 years. I got it running in one day with a new battery, starter relay, and (eventually) a fuel filter and a carb rebuild kit.  I'm (currently) daily driving it.
Notes: Has a D44, but I don't know if it's factory. It has a 3.54 ratio and it's a limited slip axle. Seems like it's a weird combination of that engine/transmission/rear axle.
Current owner: Terrence Brunson
I'd like to know which trim this truck is and if it has the Metric Ton (or whatever we call it stateside) package.
how many factory leafs in the leaf pack?  3+1 is standard.  4+1 is MT for 86.  theoretically the dana 44 wasn't available yet though.  the AMC-20 was the heavy duty axle for 86.  :dunno:
*ZZ TRIM STYLE ZZ - BUCKET SEAT
-ZZ
AGY
AJQ
AJY Popular Equipment Package
APP TWO TONE PAINT PACKAGE - (MEX POLICE)
BAC 75 AMP ALTERNATOR
BCQ Battery - Maintenance Free
CGW
CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ
CUF FULL LENGTH FRONT CONSOLE
DDJ 5SPD MANUAL TRANS
EFB ENGINE - 2.8L GM 6CYL
GAC ALL WINDOWS - TINTED GLASS
GFD SLIDING RR WINDOW
GTZ MIRRORS - MANUAL REMOTE
HAA AIR CONDITIONING - FRONT
HCC HEATER W/UPR LEVEL VENTIL - TYPE II
JAY Instrument Cluster w/Tach
JGB Clock - Digital
JJA CIGAR LIGHTER - FRT COMP
K60 BODY SIDE MLDGS - VINYL
LMA HALOGEN HEADLAMPS
MDA FRT LICENSE PLATE ATTACH REQUIRED
MFD BRIGHT GRILLE - TYPE I
NAA ESA W/CATALYST (EXC CALIF SYSTEM)
NFA TANK - 23 GAL FUEL
NMB ENGINE COOLING - STANDARD DUTY
RAC RADIO - AM/MTR
SBA POWER STEERING
SCG LEATHER STRG WHEEL - EURO/SPORT TYPE
Build date 7/7/86
Body code TM62
A rather late 86 too.
I wonder if that's the code for the wheels? Mine are the 10 spoke aluminum ones with black jeep logo center caps (which I still have all 4 of)
I need better pictures. I only have the ones from when I pulled it out of its 5 year resting place.
It also has that funky brake bias pushrod thing on the rear end as well.
all MJs have that. :L:
the original code list for your truck would be 4 or 5 times as long as what you see there.  if you go look at a 91 or 92 MJ, you'll see what I mean.  early years have far more missing info. :(
  • 1 month later...
I'll be honest. I snapped this picture while I was working on replacing the corner window, and I was kind of in a rush. The sun was going down and I plan on taking it to work tomorrow. I now regret not getting a better shot.
Looking at what is there, it doesn't really seem to match. And to make it worse, the axle rations apparently supposed to be 4.10, and mine is 3.55. Explains the gutlessness I guess. That old 2.8 doesn't make much power. But! The current axle IS a D44, so that's nice. I guess it likely had a 35 originally.
