Pete M Posted May 5, 2022 Share Posted May 5, 2022 how similar is the 2.5L harness to the 4.0 harness? are they available new still? Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 5, 2022 Share Posted May 5, 2022 Are you talking about the two halves that are available aftermarket for the 4.0L? Regardless both harnesses aren’t the same but both halves can be snapped together but you’d have to adapt and modify the 4.0L harness to work with the 2.5L. That’s what I did with mine to just replace/refresh the plastic lines. Link to comment Share on other sites More sharing options...
Pete M Posted May 5, 2022 Author Share Posted May 5, 2022 yup, thems the ones. Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 5, 2022 Share Posted May 5, 2022 Yeah that harness works. Just gotta modify it and have some rubber vac line to splice lines together. And cut the bigger line that would be from the valve cover to air box on the 4.0L Link to comment Share on other sites More sharing options...
