Parei_doll_ia Posted April 22, 2022 Share Posted April 22, 2022 Is anyone using a wideband UEGO and sending the signal to the ECU through the REM? (Like Nick's video https://www.youtube.com/watch?v=YujtUYPJikA&ab_channel=NickInTimeFilms) I'm considering it because there doesn't seem to be any replacement Renix O2 sensors that actually work anymore. (I got a NTK last year, but it's the exact same metal body sensor as the Bosch that doesn't perform well) I just bought an OMIX sensor from Quadratec hoping that it's old stock that has a ceramic body, but I'm returning it if it shows up as metal bodied. I'm getting a loop fault lean code on the REM at the 1st closed loop attempt and when I accelerate for an extended period. (not WOT, just normal driving) The ST climbs up to 255 and CL fails. LTFT is around 160. vO2 doesn't swing much, just sits at 2-2.5V. Ground seems good, and the sensor has 4.6 Ohms. I thought fixing the busted paper manifold gasket that the Pacesetter headers came with would help, but had no change. The only OEM sensor that I have pegs lean immediately and constantly. Link to comment Share on other sites More sharing options...
Parei_doll_ia Posted April 24, 2022 Author Share Posted April 24, 2022 I guess I'm the only one then. I live right next to Summit Racing, so I went ahead and did it. It wasn't too hard, but also confusing in spots. With some emailing Nick back and forth a few times, I got it sorted out. I still have to clean up the wiring before I drive it, but it was swinging much better at idle. I'll probably make a writeup in a few days. Link to comment Share on other sites More sharing options...
cruiser54 Posted April 25, 2022 Share Posted April 25, 2022 Sensor is supposed to have more resistance on the heater circuit. 8 to 13 ohms? Link to comment Share on other sites More sharing options...
boxyjeep Posted April 25, 2022 Share Posted April 25, 2022 Very interested in this. I just installed an ATK 4.6L stroker and have been trying to find the right size injectors with a frequent lean condition. I wonder if a problematic O2 sensor could be the issue. Link to comment Share on other sites More sharing options...
Parei_doll_ia Posted April 25, 2022 Author Share Posted April 25, 2022 4 hours ago, cruiser54 said: Sensor is supposed to have more resistance on the heater circuit. 8 to 13 ohms? That was the heater circuit on the sensor that had 5 Ohms actually. Gray to black is open loop. The new sensor is heated through the AFR gauge circuit so it doesn't really matter anymore. After a few drives, my LTFT hasn't budged from 126 which is perfect 3 hours ago, SoCalJeepComanche said: Very interested in this. I just installed an ATK 4.6L stroker and have been trying to find the right size injectors with a frequent lean condition. I wonder if a problematic O2 sensor could be the issue. I think doing a stroker is why Nick did the work on this. Mine is completely stock apart from the headers and 746 injectors but it's been running great so far. I think the UEGO in the AEM gauge is the same Bosch sensor as the o2 sensors on my mk6 TDI. Link to comment Share on other sites More sharing options...
