KBRAY88MJ Posted April 8, 2022 Share Posted April 8, 2022 My truck was originally a 2wd with the BA10 transmission. I swapped an AX15/231 out of a 97 Cherokee. Where can I find the mechanical drive for the Speedo? The np231 currently just has the plug for the electric Speedo sensor. I already bought the correct length cable. Link to comment Share on other sites More sharing options...
Eagle Posted April 8, 2022 Share Posted April 8, 2022 Can't you just use the speedo drive out of the BA 10/5? Link to comment Share on other sites More sharing options...
KBRAY88MJ Posted April 8, 2022 Author Share Posted April 8, 2022 50 minutes ago, Eagle said: Can't you just use the speedo drive out of the BA 10/5? Maybe I could have. I’m not sure. The BA was long gone before I ever realized I need a different Speedo style. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted April 8, 2022 Share Posted April 8, 2022 Just swap to the old style speedo sender for the 231. you will need to use the "long" style speedo gear but otherwise it just bolts in. All those speedo sending units/vss in the MJ/XJ/YJ/ZJ/TJ np231 are physically interchangeable with the accompanying correct style speedo gear Link to comment Share on other sites More sharing options...
KBRAY88MJ Posted April 8, 2022 Author Share Posted April 8, 2022 11 minutes ago, ghetdjc320 said: Just swap to the old style speedo sender for the 231. you will need to use the "long" style speedo gear but otherwise it just bolts in. All those speedo sending units/vss in the MJ/XJ/YJ/ZJ/TJ np231 are physically interchangeable with the accompanying correct style speedo gear The issue I’m having is finding one of the mechanical sending units. I’ve searched online everywhere and can’t seem to locate one. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted April 8, 2022 Share Posted April 8, 2022 13 minutes ago, KBRAY88MJ said: The issue I’m having is finding one of the mechanical sending units. I’ve searched online everywhere and can’t seem to locate one. NP231J Transfer Case Mechanical 26 Tooth Speedometer Gear New Process OEM | eBay Link to comment Share on other sites More sharing options...
KBRAY88MJ Posted April 8, 2022 Author Share Posted April 8, 2022 30 minutes ago, ghetdjc320 said: NP231J Transfer Case Mechanical 26 Tooth Speedometer Gear New Process OEM | eBay Thank you. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted April 8, 2022 Share Posted April 8, 2022 9 minutes ago, KBRAY88MJ said: Thank you. No problem. They are available new too it looks like but they're pricey! Link to comment Share on other sites More sharing options...
KBRAY88MJ Posted April 8, 2022 Author Share Posted April 8, 2022 4 minutes ago, ghetdjc320 said: No problem. They are available new too it looks like but they're pricey! I just went ahead and bought the one from the link. Link to comment Share on other sites More sharing options...
