My truck was originally a 2wd with the BA10 transmission. I swapped an AX15/231 out of a 97 Cherokee. Where can I find the mechanical drive for the Speedo? The np231 currently just has the plug for the electric Speedo sensor. I already bought the correct length cable.
50 minutes ago, Eagle said:
Can't you just use the speedo drive out of the BA 10/5?
Maybe I could have. I’m not sure. The BA was long gone before I ever realized I need a different Speedo style.
Just swap to the old style speedo sender for the 231. you will need to use the "long" style speedo gear but otherwise it just bolts in. All those speedo sending units/vss in the MJ/XJ/YJ/ZJ/TJ np231 are physically interchangeable with the accompanying correct style speedo gear
The issue I’m having is finding one of the mechanical sending units. I’ve searched online everywhere and can’t seem to locate one.
4 minutes ago, ghetdjc320 said:
No problem. They are available new too it looks like but they're pricey!
I just went ahead and bought the one from the link.
