Gas tank needed...
It probably isn't your tank that's leaking.
I replaced the tank in my '87, drove to the gas station to enjoy my first fill-up in over a year -- and was astonished to find gasoline pouring out onto the pavement as I pumped. What happens is that the hard tubes for the gas lines break loose from the mounting plate where they go through the plate into the tank. Replacement fuel pumps don't include the mouting flange, so a new fuel pump probably isn't the answer.
I saw a post by someone (don't remember if it was here or on NAXJA) who just epoxied around the tubes and solved the problem. Once the ground here dries up a bit I'll do that to mine.
Fill yours to the point where it starts to drip, then crawl under and take a careful look at where it's coming from.
