New Military Wrap Spring Clicking
Did you torque them before, or after, you had the truck down on the ground supporting its own weight?  I'd say try loosening and retorquing.
Also remeber the rear shacke bolts should be loose enough to allow the shackle to swing as the spring flexes.
I did torque it in the air, didn't think about that. I loosened the bolts and it still did it, but I think I found the problem. There was some rust in the pocket that was rubbing on the wrap. I hit it with a hammer and a flathead a couple of times and a good bit of it fell out. It didn't make the sound anymore, so it must've been oxide jacking pushing the rust into the wrap with how tight these springs fit.
A piece of what fell out:
