TheSiLvAPython Posted February 22, 2022 Share Posted February 22, 2022 My first Jeep and first manual. Manufacture date 6/89 7ft bed Engine 4.0L I6 Transmission 5-speed manual (ax15 I think but don't know for sure) Rear wheel drive Dana35 rear axle Front axle unknown. Its a RWD Located in pierce county washington. Pretty sure the Jeep came from Canada As far as I know it does not have any fancy factory things(I also don't know what it was factory equipped with) I just so happen to stumble along this website which I have already learned a lot from. I have only owned this since around october 13th, 2021. I think the majority of the timeI have been fixing the domino effext of things that I broke. [(Things like the pinion yoke on the rear axle from learning how to drive the manual.) Which led to re welding the clutch pedal because I completely broke it.) That caused my starter to go out from driving with no clutch and having to shut the jeep off and start it again after every stop.... Which eventually led to changing my motor mounts. Now just trying to fix it up so it is running smooth and hope to do a 4×4 conversion. New paint one day. Hope to lift it. I have my goals of what I want to do and with the help of others on here I think I can accomplish those goals. I got carried away Here motor pictures. I will add others another time. Link to comment Share on other sites More sharing options...
jdog Posted February 24, 2022 Share Posted February 24, 2022 Build Date: 6/13/89 Body: tl62 Selling Dealer: PERFORMANCE JEEP EAGLE INC Everett, WA BGAS Power Front Disc/Rear Drum Brakes BJAS DESCRIPTION NOT AVAILABLE BKPS 10x2.5 Rear Drum Brakes CSRS Passenger Assist Handles CUMS Mini Floor Console DMMS 3.07 Rear Axle Ratio DRJS Dana 35 Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass GNAS Rear View Day/Night Mirror GUAS Open HCDS Do Not Use - See HCA JAAS Instrument Panel JBFS Instrument Panel Black Bezel JCAS 85 MPH Primary Speedometer JKBS KWXS DESCRIPTION NOT AVAILABLE K3ZS STRIPE/BADGE/MOLDING/COLOR LAFS Seat Belt Alert-Driver Seat only LAPS Shift Indicator Warning Lamp LBCS Glove Box Lamp LCJS LMAS Halogen Headlamps MB1S Black Front Bumper MFFS Black Grille MHBS Fender Flares MMCS Rear Door Solid Window Insert MMGS Belt Moldings MMJS Molded-In-Color Fender Flares NAAS Federal Emissions NBAS NBKS EVAP Control System NDAS Catalytic Converter NF5S 23 Gallon Fuel Tank QB3S Blue SCBS Perforated Steering SFAS Standard Duty Front Shock Absorbers SGAS Standard Duty Rear Shock Absorbers TADS TBMS Tire Carrier Winch WJKS 15X6.0 Styled Steel Wheels XBSS Pickup Box XFAS -35F Protection Anti-Freeze YAAS Build To U.S. Mkt. Specifications Z1AS GVW/Payload Rating 1AAS U.S. Dealer Retail 172S Zone 72-Portland *B1 DESCRIPTION NOT AVAILABLE -SA Charcoal CBAP Straight Back Bench Seat CKA Carpets DBBC All Manual Transmissions DDQ 5-Speed Manual Transmission EAAC All Engines EAFC ERB 4.0L I6 MPI Engine GRVP Left Manual Mirror JAY DO NOT USE - See JP, KA classes JGBP JHA Var Intermittent Windshield Wipers JJA Cigar Lighter MBJ Front Bumper MDAP Front License Plate Bracket PB3 Blue RAAC All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCDP 4 Speakers SBAA Power Steering SUA Tilt Steering Column TAAC All Tires TBB Full Size Spare Tire TPF P205/75R15 BSW All Season Tires YEP Manuf Statement of Origin YGEA 5 Additional Gallons of Gas Z01P Rear Spring Group I Z58P Left Front Spring Group Viii Z78P Right Front Spring Group VIII 5ALA DT-Vehicle Family Link to comment Share on other sites More sharing options...
