Early style speedometer cable sources?
I have an 87 2.5 ax5 non cruise that I 4wd swapped. I'm having the hardest time finding the correct speedometer cable for this thing. Everywhere I look they only have the newer style with the plastic end. I'm looking for the metal end that goes to the speedo and has a metal clip that holds it. I even tried looking up older cherokee cables on rock auto and if the parts pictures are correct they don't offer it. Anyone have a good part number or source?
  • 1 month later...
17 minutes ago, coheed said:
Resurrecting this thread cause my cable is making an awful clicking noise. Eaglescout, do you happen to know if we can get the 84-86 style cable off Rockauto, or from a parts house?
Hmmm honestly I do not know. I can give you the whole slew of part numbers that supersede to the one above.
I tried the part number you post above and only found Mopar part houses. I can try the other numbers you can give me, but it'll probably be the same result.
I’ll find the other numbers and do some research and see what I can come up with.
