Orca1 Posted December 9, 2021 Share Posted December 9, 2021 Looking for help sourcing a new driveshaft for a 1988 2wd short bed. Anyone have these on the shelf or do I need to get one made? Link to comment Share on other sites More sharing options...
Andy in Pa Posted December 9, 2021 Share Posted December 9, 2021 Where are you? I have one in my shed. Not new, but worked perfectly before I converted to 4wd. Link to comment Share on other sites More sharing options...
Orca1 Posted December 9, 2021 Author Share Posted December 9, 2021 I'm out in sunny Arizona. If your willing to let it go for a reasonable price and shipping isn't crazy maybe we can work something out. The good thing about being in Arizona is no rust, the bad is rubber doesn't like the heat. The rubber sleeve in my driveshaft is toast. Link to comment Share on other sites More sharing options...
Andy in Pa Posted December 9, 2021 Share Posted December 9, 2021 8 minutes ago, Orca1 said: I'm out in sunny Arizona. If your willing to let it go for a reasonable price and shipping isn't crazy maybe we can work something out. The good thing about being in Arizona is no rust, the bad is rubber doesn't like the heat. The rubber sleeve in my driveshaft is toast. I would be tempted to just cut that outer sleeve/rubber off and see if it really affects the driveline that much. I have spoken to some driveline experts, and when a driveshaft gets to around 45" long, that is when harmonics and weird driveline vibes may become noticeable. As long as the rest of the driveshaft is OK, I would try that first. Link to comment Share on other sites More sharing options...
Orca1 Posted December 9, 2021 Author Share Posted December 9, 2021 The sleeve is on the inside of the shaft. Not something you could cut off. I just bought this truck a month ago and have been chasing this high speed vibration problem. Vibration starts at about 60mph and smooths out about 70mph. No problems below 60. Put a dial gauge on the drive drive $#!& and it varies about 30 tho. Already did a bunch of work on the front end now working my way back. Link to comment Share on other sites More sharing options...
ExpatMJGuy Posted December 10, 2021 Share Posted December 10, 2021 I'm in the same situation converting 2wd to 4wd and am ISO a 4wd drive shaft. That or mine will need converted. Link to comment Share on other sites More sharing options...
Pete M Posted December 10, 2021 Share Posted December 10, 2021 denny's driveshafts. or just google "driveline shop" and it should bring up something near you. Link to comment Share on other sites More sharing options...
