Hey guys,
Using @cruiser54 guide for TPS adjustment for automatic.
On the 3 pin connector I can get a base voltage of around 4.86, but I cannot get an OUTPUT voltage? (Is that possible)
4 pin connector I can get BOTH base and OUTPUT voltage.
Need help on the ENGINE side of the TPS. Any thoughts?
On 11/14/2021 at 8:06 AM, cruiser54 said:
TPS is likely bad.
So @cruiser54 was spot on (what a surprise 😆).
I replaced the TPS with an OEM one today and lo and behold, the output voltage on the flat connector went to 0.82 V (17% of 4.85 my base voltage)
Long story short, bad TPS
