7 minutes ago, CornFed said:
Do you need to do a lift for 31s?
technically no, but you must use stock rims (or else the tires get pushed into the flares while turning) and it's a good upgrade to add in WJ lower arms to handle any rubbing.  :L:  also, not all 31s are actually the same size so it's possible that the larger ones might not fit without some minor rubbing.
2 hours ago, Yoopermanche20 said:
Hey guys, just put a 3 inch lift on my Comanche, would 33s fit without rubbing? Or should I stick with a 31?
31s will work without trimming.  and will rob less power.  :L:
