Everett Posted October 26, 2021 Share Posted October 26, 2021 My bearings broke and sheered the steering nuckle spindle, to the point its snapped in half, i went to the local jeep dealer and the part i need was discontinued in 2002 lol, does anyone have any ideas where i could get it from? Link to comment Share on other sites More sharing options...
eaglescout526 Posted October 26, 2021 Share Posted October 26, 2021 Year and 2wd or 4wd? Link to comment Share on other sites More sharing options...
mjeff87 Posted October 27, 2021 Share Posted October 27, 2021 Junkyard or someone with an older 2WD beam axle (with spindles). 92+ XJ's/MJ's used a unit bearing with a stub shaft to replace the older spindle design. You can swap one on to the inner C of an older axle, but you'll need to replace the brakes (rotor, caliper and pads) to a later model setup to match. Then you end up with mis-matched brakes on the front end..... I do have my old (87) 2WD axle still, but it's in a barn about 300 miles north of me at the moment. For what it's worth, it'd be probably just as much work to swap a whole new 2WD axle under it, IMHO. Link to comment Share on other sites More sharing options...
