Almohlhel Posted October 16, 2021 Posted October 16, 2021 Why plug of sender (C307) =12 v always ? and tempruter gauge not work .
Ωhm Posted October 16, 2021 Posted October 16, 2021 With C307 disconnected circuit has no current (A) flow. In your other posting (temperature sender) perform the test posted by @gogmorgo. See if you can get the gauge to move from one end to the other end. HOT to COLD or COLD to HOT.
Almohlhel Posted October 16, 2021 Author Posted October 16, 2021 56 minutes ago, Ωhm said: With C307 disconnected circuit has no current (A) flow. In your other posting (temperature sender) perform the test posted by @gogmorgo. See if you can get the gauge to move from one end to the other end. HOT to COLD or COLD to HOT. I make test but same problem
