Hey guys! I have a delema. My 89 Manche has manual windows and the cable on the Drivers side is rotted in two, and the window will only go down about 3 inches, then I have to push it the rest of the way, and vise versa up. my question is...I can buy POWER window assemblies on AMAZON for $70.00 . Can these 1989 Manual Window Doors, be converted to Power, using the power regulator set up, or is the glass different in a power window Comanche? The manual window regulators are hard to find, and expensive.
3 hours ago, acfortier said:
I was able to find a manual regulator at the junkyard for $25. I believe you can get them out of a Cherokee from 84-96.
:yeahthat:
If you do get a regulator from the junkyard, make sure you clean and lubricate it to prevent this from happening again.
You can convert to power windows too if you add the appropriate wiring. The glass does not have to be replaced.
