Horn Contact Repair Kit
As I was taking apart my steering column to fix the turn signal switch, I think the horn contact portion in the cancelling cam exploded on me, and I can't seem to find the spring that was in there. Also looks like buying a new cancelling cam doesn't include the stuff for the horn contact.
Would this be proper repair kit? https://www.dormanproducts.com/p-5975-83230.aspx
2 minutes ago, eaglescout526 said:
I went with that exact repair kit. It works fine. I am not sure if it’s meant for the Jeep steering wheel but it works as it should. You’ll need to install the spring first, then the spacer on the contact shaft, then the shaft into the spring.
Thanks! Ordering one now.
  • 2 months later...
Alright, re-assembled and now the horn is constantly on once I put the relay back in. There doesn't seem to be any play with the steering wheel horn section itself (as in, if you push on it, nothing moves--so it seems that it's stuck on?)
Not sure what to check-- after I put the spring lock plate back on, I just re-attached the steering wheel as an entire assembly--didn't take apart the 3 screws holding that plastic piece down.
