New at this, trying to setup Revolution 4.56 gears in a 8.8
How do these patterns look? They seem deep on the teeth. Revolution backlash spec is .011-.016", I'm on the tight side of .012"
Pinion preload is 20 in/lb. Spec from Revolution is 16-28 in/lb with new bearings.
Any advice
Pinion depth looks a touch too deep but you have an pretty even pattern on the power and coast side of the ring teeth. Should be fine. You could shim the carrier over to loosen the backlash slightly.
