Snowbird22 Posted August 23, 2021 Share Posted August 23, 2021 Hey, bought a 1990 Comanche that had a lift and 33” tires. Have to downshift to get it up hills. I was just going to get it regarded, but the front axel now won’t roll, so I was thinking of swapping to Dana 44s front and rear. I’ve been told so many different things about this. what I think is the way to go is wagoneer 44s because the pumpkin on the front is on the driver side. I guess where I need advice is if it’ll be a fairly easy swop or not. Not sure about bolt patterns and break assembly etc. Link to comment Share on other sites More sharing options...
Big Dan Posted August 23, 2021 Share Posted August 23, 2021 Depending on the year, wagoneer axles have passenger side pumpkins as well.Wagoneer is also leaf spring. So, it would not be an easy swap. Sent from my Pixel 4 XL using Tapatalk Link to comment Share on other sites More sharing options...
Pete M Posted August 24, 2021 Share Posted August 24, 2021 define "easy". can you weld? or are you looking for a bolt-in? Link to comment Share on other sites More sharing options...
