Hey, bought a 1990 Comanche that had a lift and 33” tires. Have to downshift to get it up hills. I was just going to get it regarded, but the front axel now won’t roll, so I was thinking of swapping to Dana 44s front and rear. I’ve been told so many different things about this.
what I think is the way to go is wagoneer 44s because the pumpkin on the front is on the driver side.
I guess where I need advice is if it’ll be a fairly easy swop or not. Not sure about bolt patterns and break assembly etc.
Depending on the year, wagoneer axles have passenger side pumpkins as well.
Wagoneer is also leaf spring. So, it would not be an easy swap.
Sent from my Pixel 4 XL using Tapatalk
  • Pete M changed the title to Axle trouble
