1J7FJ26P2ML565777
Pete M
*C1 TRIM STYLE C1 - CLOTH &&&& VINYL BENCH SEAT
-SA CHARCOAL
169 Zone 69-Phoenix
1AA U.S. Dealer Retail
ALA
APA Monotone Paint
BAF 130 Amp Alternator
BCY 475 AMP BATTERY
BGA Power Front Disc/Rear Drum Brakes
CBA Straight Back Bench Seat
CKJ Black Vinyl Floor Covering
CUM Mini Floor Console
DBB All Manual Transmissions
DDQ 5-Speed Manual Transmission
DHN Command-Trac Part Time 4WD System
DJH 230MM Front Axle
DMF 4.10 Rear Axle Ratio
DRJ Dana 35 Rear Axle
EPE Engine - 2.5L Power Tech I-4 Cyl.
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GRV Left Manual Mirror
GUA Open
HAA Air Conditioning
JAZ DO NOT USE - See JP, KA classes
JCA 85 MPH Primary Speedometer
K3Z STRIPE/BADGE/MOLDING/COLOR
KDN
KWS STRIPE/BADGE/MOLDING/COLOR
LAP Shift Indicator Warning Lamp
LBC Glove Box Lamp
LMA Halogen Headlamps
MB1 Black Front Bumper
MFF Black Grille
MHB Bright Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMJ DRIP TROUGH MOLDINGS - TYPE I
NAA Federal Emissions
NBK EVAP Control System
NF2 18.5 Gallon Fuel Tank
NMC Heavy Duty Engine Cooling
PW7 Bright White Clear Coat
QW7 Bright White Clear Coat
RA8 Delete Radio
SBA Power Steering
SCE Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TBB Full Size Spare Tire
TBM Tire Carrier Winch
TNC P195/65R15 BSW AS Touring Tires
TZH Michelin Brand Tires
WJK 15X6.0 Styled Steel Wheels
WLY All Steel Wheels
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z5A GVW/Payload Rating
Z64 Left Front Group XIII
Z82 Right Front Spring Group XI
Build date 12/18/90
Body code JL61
Sold by STEVE CHRISTY CHRY-JEEP, TUCSON AZ
