1J4FJ58L6KL533033
500 MJ
Should be an ‘89 XJ. I didn’t have time to get a good look underneath (and the gas tank/weeds were in the way. I am wondering if it has a D44 Rear end?
Very well optioned and it has a 242 tcase.
Located at Team Kirchhayn / APR - Fredonia WI.
6DC138FB-361D-4353-A885-8A52743E0952.jpeg.903be06e04be377dad352a1bda2bf24d.jpeg04E60D87-13FE-45D9-8C0E-F1ABC4C2D609.jpeg.ba9b73939939fff589722b5e00d8ada7.jpeg
APAS  Monotone Paint
 BGAS  Power Front Disc/Rear Drum Brakes  BJAS  DESCRIPTION NOT AVAILABLE BKPS  10x2.5 Rear Drum Brakes
CDBS  Reclining Front Seats
CKBS  Floor Carpet
CKVS  Cargo Area Storage
CLES  Front Rear Floor Mats
CSAS  Spare Tire Cover
CSCS  Cargo Compartment Cover
CSRS  Passenger Assist Handles
CUFS  Full Length Floor Console
DGSS  4-Speed Automatic AW4 Transmission
DHAS  Lock-Up Torque Converter
  DHSS  Floor Mount Automatic Shift Lever DJHS  Dana M30/181MM Front Axle
DMDS  3.55 Rear Axle Ratio
DRJS  175MM Rear Axle
GACS  Tinted Glass Windows
GBBS  Tinted Windshield Glass
GCBS  Front Door Tinted Glass
GECS  Front Left Side Sliding Window  GEDS  Tinted Rr Drs/Qtr/Liftgate Glass  GFAS  Rear Window Defroster
GNAS  Rear View Day/Night Mirror
GNBS  Driver Side Illuminated Sun Visor  GTBS  Power Heated Mirrors
HGAS  Hood Insulation
JAAS  Instrument Panel
JAYS  DO NOT USE - See JP, KA classes JBES  Instr. Panel Diamond Weave Bezel  JCAS  85 MPH Primary Speedometer  JGBS  Digital Clock
JHAS  Var Intermittent Windshield Wipers  JHBS  Rear Window Wiper/Washer
JJAS  Cigar Lighter
JKBS  MOPAR Hood Lock
KKES  DESCRIPTION NOT AVAILABLE  K3SS  DESERT SAND P/C - FENDER FLARES LAFS  Seat Belt Alert-Driver Seat only
LAJS  Headlamps On Warning Chimes  LBBS  Courtesy Lamps
LBCS  Glove Box Lamp
LBDS  Ash Tray Lamp
LBES  IP LED Ambient Light Pipe
LCDS  Map/Dome Reading Lamps
LDBS  Cargo Compartment Lamp
LDHS  U/Hood, Removable/Rechargeable Lamp
LHDS  Headlamp Off Time Delay
LMAS  Halogen Headlamps
MB3S  Bright/Body Color Front Bumper MB7S  Bright/Gray Mist Rear Bumper  MCAS  Front Bumper Guards
MCBS  Bronze Fascia Applique
MFMS  Grille-Black/Bright
MHBS  35 Tire Body Color Fender Flares  MMCS  Rear Qtr Solid Window Insert MMGS  Belt Moldings
MMJS  Molded-In-Color Fender Flares  MMPS  Bright Day Light Opening Moldings MTAS  Rear Fascia Skid Plate Applique  MWAS  Roof Rack
NAAS  Federal Emissions
NBAS  Underground Calibration
NBKS  EVAP Control System
NDAS  Catalytic Converter
NFAS  20 Gallon Fuel Tank
QS3S  Sapphire Silver Blue Met Clear Coat  SBAS  Power Steering
SCGS  Leather Wrapped Steering Wheel  SFAS  Standard Duty Front Shock Absorbers
SGAS  Standard Duty Rear Shock Absorbers
TBCS  Compact Spare Tire
TBLS  Inside Mounted Spare Tire
WJMS  15X7.0 Chrome Wheels
XFAS  -35F Protection Anti-Freeze
YAAS  Build To U.S. Mkt. Specifications  Z5BS  GVW Rating - 4900#
1AES  BUX Contract Assembly
155S  Zone 55-Milwaukee
4FMS  Fleet Option Editor
