Power window modification
90 Comanche and the manual regulator went up. But a conversion kit to make it power windows. The wiring diagram says to get the power from the + of the ignition switch. I am trying to get confirmation of which wire (color) is the positive and where to  splice in. I appreciate any help.
Ok thanks.  I guess I would just meter them as I turn the key on and off.  I appreciate your help.
They also have a wire, circled in red, that gets hooked into what I think is the dome light wire.  Not sure but I would guess that is so the door switches light up.  Thanks again.
My 89 has power windows added (by the previous owner) and window power supply is tied into the thick brown wire, which I understand to be the ignition power supply. Everything works, so I believe that is the correct one. I've yet to figure out what to the the power lock switch supply to though.....
