ghetdjc320 Posted August 7, 2021 Share Posted August 7, 2021 I swapped the original long sender for a newer (94+) short sender so I no longer need this gear. Should work in all 1993 and prior np231/242 cases for both the electric and cable driven speed sensor. Does not fit 2wd vehicles. You’ll have to see if the ratio is close to what you need but I used this for 4.56 gears and 33” tires and the speedo was spot on. $10 plus shipping. Link to comment Share on other sites More sharing options...
Jesse J Posted August 7, 2021 Share Posted August 7, 2021 dmed Link to comment Share on other sites More sharing options...
ghetdjc320 Posted August 7, 2021 Author Share Posted August 7, 2021 Replying now Link to comment Share on other sites More sharing options...
Archived
