m2bandit Posted July 19, 2021 Share Posted July 19, 2021 This switch panel allows you to add two switches to the stock panel position. This panel replaces the original panel, blockoff plate, or one switch panel to the left of the steering column. It eliminates stock panel labels that mislabel your switches. This is a new panel made of strong, temperature resistant ABS plastic. It fits two Carling rocker type switches (Carling, Contura). The finish is raw ABS plastic that can be painted as needed. Switches not included Price: $25 Shipped Link to comment Share on other sites More sharing options...
jamespwsullivan Posted August 16, 2021 Share Posted August 16, 2021 @m2bandit Looking for calling on Amazon it appears that their switches can have slightly different sized mounting holes. What are the measurements you are using? Also, would you consider making a blank plate and cutting a hole for a gauge mount? Thanks Link to comment Share on other sites More sharing options...
m2bandit Posted August 17, 2021 Author Share Posted August 17, 2021 1 hour ago, jamespwsullivan said: @m2bandit Looking for calling on Amazon it appears that their switches can have slightly different sized mounting holes. What are the measurements you are using? Also, would you consider making a blank plate and cutting a hole for a gauge mount? Thanks Carling dimensions are .83" x 1.45" ; 21.08mm x 36.83mm I've added a bit of tolerance for bad china knockoffs, so most everything fits. Unless it's really bad. Those are Nilights from Amazon in the photo. I can make a gauge mount if you've got the OD dimension of the gauge you have. The downside to having a blank plate would be its strength. If the panel is 100% solid it wouldn't be as strong. It sounds counter intuitive but it's better. If it wasn't 100% solid then the infill lines would be exposed where it's cut and the edge of the hole wouldn't be very strong. Link to comment Share on other sites More sharing options...
jamespwsullivan Posted August 17, 2021 Share Posted August 17, 2021 Those measurements help a lot. I looked at two different switches that were advertised as Carling and got two slightly different sizes for mounting. Thanks! Link to comment Share on other sites More sharing options...
m2bandit Posted August 18, 2021 Author Share Posted August 18, 2021 18 hours ago, jamespwsullivan said: Those measurements help a lot. I looked at two different switches that were advertised as Carling and got two slightly different sizes for mounting. Thanks! Yeah, the Chinese USB "Carling" I got was at least 1/4" larger than it should have been. They don't seem to care about proper dimensions. Carling is actually the company the original switch was made by, the style is "Contura" since Carling makes a ton of different switches. I'm glad I could help. Link to comment Share on other sites More sharing options...
