thousender Posted July 16, 2021 Posted July 16, 2021 Does anybody know if the transmission from a TJ will fit the bell housing of a 1st gen 2.5l? If so, will the shifter linkage line up? I know transfer case clocking is different but I am planning to buy the t-case as well.
87MJTIM Posted July 16, 2021 Posted July 16, 2021 It depends.... Is yours a 4.0? Then no. If yours is a 2.5, then it should. The AX5 does not bolt to a 4.0 block. An AX15 bolts to a 4.0.
