jeepdude4 Posted February 24, 2021 Share Posted February 24, 2021 1986 Comanche Truck Engine / Trans / Transfercase / Front axle / Rear axle / Wheelbase. 2.5 Ltr 5 speed standard transmission with 4wd Build date: (its on the driverside door sticker, in the form of month and year) Current Location: Region will do, state, and area of state. Houston, Mississippi Status: Is it still on the road, is it in the junkyard? Project awaiting work? Being worked on. Preparing to rebuild it starting next week. I need to figure out the gear ratios for it because i think the rear-end is locked up. Notes: Anything that makes this comanche different from the rest. Skid plates, plows, lights, bumpers, weird factory options... Would also be a good place to note the exterior color, and the interior color and combination, IE, Bench or buckets, Vinyl or cloth, column shift or floor shift. Has Leather buckets from a Cherokee limited. Current owner: Me Link to comment Share on other sites More sharing options...
eaglescout526 Posted February 24, 2021 Share Posted February 24, 2021 Need a VIN and I can get you a build sheet/date Link to comment Share on other sites More sharing options...
fiatslug87 Posted February 24, 2021 Share Posted February 24, 2021 @jeepdude4 see above request. Link to comment Share on other sites More sharing options...
jeepdude4 Posted February 25, 2021 Author Share Posted February 25, 2021 23 hours ago, eaglescout526 said: Need a VIN and I can get you a build sheet/date Thanks I will post a VIN soon I am about 2.5 hours from the truck. Link to comment Share on other sites More sharing options...
eaglescout526 Posted February 25, 2021 Share Posted February 25, 2021 4 minutes ago, jeepdude4 said: Thanks I will post a VIN soon I am about 2.5 hours from the truck. Okie dokie! No absolute rush. Link to comment Share on other sites More sharing options...
