Transfer case vacuum hoses
Hello. I was swapping out my speedometer cable and accidentally pulled all those colorful vacuum lines out of my transfer case. I put them back in and now I have a light on my cluster that says "part time" and when I make a right turn there is a horrible crunching sound. Is there an order to what color goes where? What did I do?
9 minutes ago, ratty said:
What controls it?
Do you mean, what controls shifting in to 4H and 4L?  That would be the shifter in the cab.  Look under the truck to make sure the linkage is hooked up properly and not binding against anything.  If it is still won't shift, then the problem is internal.
Everything looks good underneath. I have no idea how this happened
5 minutes ago, yxmj said:
Color coded diagram below
Connect them correctly and see if you still have a problem
Everything is connected, unless I didn't connect the hoses in the right order on the tcase. Is that a possibility? It's the photo I posted.
I had a problem with mine where the vacuum connector on the front axle no longer held vacuum.  It couldn't pull the collar over to engage 4wd.
First I performed the CAD bypass to make the vacuum lines unnecessary.  Later, I sapped axles to a non-CAD.  Problem solved!
Sounds like a future project for me.
