Brokeboi Posted December 30, 2020 Posted December 30, 2020 Quick question (hopefully). Putting a new power steering pump in my 90 Comanche, 2.5l. When I disconnected the old PS pump high pressure line (top finger) this is what it looked like. New pump looks like bottom finger. I assuming i just need to take the nipple with the o-ring off the old high pressure line, then that long cylinder before the bigger nut will go in the pump, right? Any help is appreciated! Thanks
Big Dan Posted December 30, 2020 Posted December 30, 2020 The part scribbled in red needs to come off. When doing the job in the future, torque needs to be applied where the green circle is, so the red scribble part stays in the pump. Sent from my Pixel 4 XL using Tapatalk
