Muncher Posted December 1, 2020 Share Posted December 1, 2020 Hey so only my rpm gauge is working right now. I took my gauge cluster off. What should I be looking for to see what's wrong? Or something else I should be looking for to fix this problem Link to comment Share on other sites More sharing options...
Muncher Posted December 1, 2020 Author Share Posted December 1, 2020 Link to comment Share on other sites More sharing options...
Muncher Posted December 1, 2020 Author Share Posted December 1, 2020 Seems like maybe the battery gauge might be working but none of the other ones Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 1, 2020 Share Posted December 1, 2020 Maybe you have idiot light senders for your gauges, bad grounds, dirty cluster contacts, dirty sensor contacts. Could be a number of things. Have you done the cruiser ground mod for the cluster yet? Link to comment Share on other sites More sharing options...
Muncher Posted December 1, 2020 Author Share Posted December 1, 2020 1 hour ago, eaglescout526 said: Maybe you have idiot light senders for your gauges, bad grounds, dirty cluster contacts, dirty sensor contacts. Could be a number of things. Have you done the cruiser ground mod for the cluster yet? No I haven't. I did clean the one ground towards the drivers door under the dash that I belive is for the gauges and I cleaned the contacts going into the gauge cluster it self. Are there any fuses for the gauge cluster that might be bad ? Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 1, 2020 Share Posted December 1, 2020 There’s only one fuse for the cluster and it would cause the whole cluster to not work. That’s about it for fuses. Link to comment Share on other sites More sharing options...
Muncher Posted December 1, 2020 Author Share Posted December 1, 2020 8 minutes ago, eaglescout526 said: There’s only one fuse for the cluster and it would cause the whole cluster to not work. That’s about it for fuses. Is that a normal size fuse or a big one? I just would find it weird that all the sensors would be bad or dirty except one. Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 1, 2020 Share Posted December 1, 2020 It’s a normal fuse in the block marked gauges. I wouldn’t find it weird. Especially if they are 30 years old. Your battery isn’t really a sensor but more of how many volts the alt is putting out. The fuel gauge is obvious but those other two just depend on how much resistance their is from the sensor to the gauge. Link to comment Share on other sites More sharing options...
Muncher Posted December 1, 2020 Author Share Posted December 1, 2020 24 minutes ago, eaglescout526 said: It’s a normal fuse in the block marked gauges. I wouldn’t find it weird. Especially if they are 30 years old. Your battery isn’t really a sensor but more of how many volts the alt is putting out. The fuel gauge is obvious but those other two just depend on how much resistance their is from the sensor to the gauge. Might need to replace all the sensors then Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 1, 2020 Share Posted December 1, 2020 8 minutes ago, Muncher said: Might need to replace all the sensors then Don’t be so quick to judge them. You can always ohm them out and make sure they are reading right. Link to comment Share on other sites More sharing options...
Muncher Posted December 1, 2020 Author Share Posted December 1, 2020 1 minute ago, eaglescout526 said: Don’t be so quick to judge them. You can always ohm them out and make sure they are reading right. Yeah ill have to do that soon Link to comment Share on other sites More sharing options...
Muncher Posted December 2, 2020 Author Share Posted December 2, 2020 Thinking that maybe my cluster is just bad. I checked out the speedo cable from the transfer case all the way to into the fire wall and there's no damage to it or anything. Yet it still doesn't work. So maybe I have to replace my cluster ? Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 2, 2020 Share Posted December 2, 2020 I see it has the cruise speed sensor adaptor in place on the back. Is that all good and connected? It’s an analog speedo and not a digital just in case you were confused. Link to comment Share on other sites More sharing options...
Muncher Posted December 2, 2020 Author Share Posted December 2, 2020 3 hours ago, eaglescout526 said: I see it has the cruise speed sensor adaptor in place on the back. Is that all good and connected? It’s an analog speedo and not a digital just in case you were confused. yeah i know that. and yes it is connected. so I'm just going to jack the rear end up tommrow take the cluster off and see if the speedo cable is spinning or not Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 2, 2020 Share Posted December 2, 2020 It could very possibly be broke. Link to comment Share on other sites More sharing options...
