knever3 Posted December 1, 2020 Share Posted December 1, 2020 I have a renix era Comanche, the wiring inside is mostly from an 87 and some from a 90 to be specific. However, I don't have any wires or sockets for the shifter, neither the 4wd or the Trans. Could someone help me find the sockets and where they tie in at? It has been many years since I put it together, somehow I missed the lighting for the trans tunnel. Thanks Link to comment Share on other sites More sharing options...
schardein Posted December 1, 2020 Share Posted December 1, 2020 The harness for the console lights looks like this. One light is for the transfer case shifter indicator, the hole it plugs into is part of the console. The other is for the transmission shifter (if automatic) and goes into the transmission shifter indicator, which is a separate part from the console. This harness plugs into the cab harness as it comes forward from the back wall of the cab, that harness includes the wire that plugs into the driver side female seatbelt. It's been a while since I had one that far apart, and can't recall if the plug is present even if the console wasn't an option, but I assume it is, especially in the early years. Link to comment Share on other sites More sharing options...
knever3 Posted December 4, 2020 Author Share Posted December 4, 2020 Hmmm... I didn't think it would come from the back of the cab. The truck used to be a manual and my seat belt wire never seemed to work with the buzzer so I will have to pull the carpet back and poke around. Odds are I never had that harness since mine was a manual. Now to find one.... Anyone? Link to comment Share on other sites More sharing options...
