Does anyone have a fix for the plastic connector at the end of the transmission shift cable for an AX4 on a '91?
The transmission end connector on the cable is worn out and can easily slip off. Is the only option to replace the entire cable or can I somehow replace just the connector? It doesn't seem to be removable.
Thanks.
14 hours ago, MiNi Beast said:
replace or superglue:dunno:
I guess it's a replacement because the connector needs to swivel on the trans mount. Oh well, add to the list...
