XJ front fenders to MJ
Any XJ fender up to 1996 will match your truck.  97+ XJ fenders bolt up just the same but they have a rounded top as opposed to the squared off top edge so it doesn't visibly match the 96- front panel.
If you struggle to find the 96- fenders, you can swap over the 97+ front panel to match the newer fenders if needed.  It is also bolt on but requires adapting the headlight wiring.
