crtdep82 Posted September 4, 2020 Share Posted September 4, 2020 Can Cherokee fender flares be used on a Comanche? And or can they be modified to fit? Link to comment Share on other sites More sharing options...
Eagle Posted September 4, 2020 Share Posted September 4, 2020 Fronts are the same. Rear Comanche wheel wells are much larger than Cherokee wheel wells, both in length and height. The only way to use Cherokee rear flares on an MJ is to get multiples for each side, cut 'em apart, and splice 'em together. Link to comment Share on other sites More sharing options...
crtdep82 Posted September 4, 2020 Author Share Posted September 4, 2020 ok thanks. Link to comment Share on other sites More sharing options...
Pete M Posted September 5, 2020 Share Posted September 5, 2020 yup. even 2dr XJs are too small for a resto. but if you're talking about aftermarket bigger flares, the XJ flares seem to also work on MJs. Link to comment Share on other sites More sharing options...
