Swampy Posted August 15, 2020 Posted August 15, 2020 What do you use for flywheel bolts. I believe the 4.0 flexplate to crank bolts are shorter than the flywheel to crank bolts. Do any 4.0l flywheel bolts work as long as its 1/2"-20 thread?
eaglescout526 Posted August 15, 2020 Posted August 15, 2020 J3151407-Flex plate bolt J3170524-Fly wheel bolt. Both of these bolts can be had new from Chrysler. Catalog does not list specs about them.
Swampy Posted August 16, 2020 Author Posted August 16, 2020 8 hours ago, eaglescout526 said: J3151407-Flex plate bolt J3170524-Fly wheel bolt. Both of these bolts can be had new from Chrysler. Catalog does not list specs about them. Thank you.
eaglescout526 Posted August 16, 2020 Posted August 16, 2020 No problem. I can find out specs if you’d like, I have a book that will help me with that.
