I have a couple of crummy instrument clusters to play with and wondered if someone would have a non-working speedo out of an old hotrod or something that they would be willing to throw at me cheap?  I'd donate $20 to the charity of your choice or whatever option you'd prefer.
I just want to see if I can manage to modify a cluster to look professional, using a nice 120 speedo from Summit or somewhere.
I'm not sure what I'd buy yet. I don't want a GPS unit so I'll need to look for one triggered otherwise.
I'd guess most of them would be about the same depth of the factory speedo (2 1/4") unit.
But I'm not opposed to cutting out the back of the housing if necessary.
If you plan on using a factory cluster you could probably use any speedo that would work for the truck.  There are some companies that make custom cluster inserts to make it all look cohesive or custom.  There are all kinds of designs you can use.
