derf Posted June 22, 2020 Share Posted June 22, 2020 I don't have my MJs at the house yet but I was pondering an idea for a plan but I need a measurement. Searching has failed me unfortunately. Can anyone tell me how tall the wheel wells are inside a short bed? Basically, I need the measurement from the pad where the roll bar mounts down to the bed. Link to comment Share on other sites More sharing options...
Pete M Posted June 22, 2020 Share Posted June 22, 2020 factory rollbar or aftermarket? I assume you're just looking for bed floor to top of wheelwell? Link to comment Share on other sites More sharing options...
derf Posted June 22, 2020 Author Share Posted June 22, 2020 Yeah, just looking at the distance from the floor to where a factory roll bar would sit. Short bed, with the flat face on the top of the wheel well. I'm bored at work and thinking up a plan for my MJ build now that I'm moving into my own house and can get started. Link to comment Share on other sites More sharing options...
Pete M Posted June 22, 2020 Share Posted June 22, 2020 I get roughly 10" to the top of the wheelwell from the floor. I can't measure to where the factory bar would sit because I don't have one. Link to comment Share on other sites More sharing options...
derf Posted June 22, 2020 Author Share Posted June 22, 2020 Thanks. That helps. Sort of.... I'm working out a cage/suspension plan and I want to use that point as a "node" that ties underneath to the frame and has a mount for coil-overs. The bed would sit on a plate there. On top of the wheel well and bolted through to the suspension mount I want a cross bar "strut tower brace" and also custom tube coming back from the top of the exo-cage behind the cab. But I also want to be able to use the bed so knowing where the cross over bar would sit helps know what I have to work around. It's lower than I want but I have a couple different ideas on how to work with it where it would sit. Link to comment Share on other sites More sharing options...
