SatiricalHen Posted May 27, 2020 Posted May 27, 2020 I thought the only leak from my tank was the over flow grommets, but I dropped the tank and looked everything over and the fuel return appears to be cracked at the sending unit. It looks like it’s maybe soldered on? How should I go about fixing this, or should I just buy a new one? Sent from my iPhone using Tapatalk
ComancheKid45 Posted May 27, 2020 Posted May 27, 2020 I've had great luck with JB weld, on the INSIDE and outside. People also have been able to brass' repair them as well. It's a common issue.
