AMC86Kid Posted May 12, 2020 Share Posted May 12, 2020 Ok guys I’m putting my dash back in today and I was needing to check all the gauges to see if they work and most importantly I needed to get the rpm gauge to work so that I can set the timing correctly does anyone have any info or links on the RPM gauge or gas gauge I know mine don’t currently work right now Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 12, 2020 Share Posted May 12, 2020 Boy do I have the wiring schematic for ya! Ill text you some pics for the cluster. Link to comment Share on other sites More sharing options...
AMC86Kid Posted May 12, 2020 Author Share Posted May 12, 2020 Ok so my volt gauge works so I know the plug in the back of the instrument cluster must be hooked up correctly but my rpm gauge just redlines the whole time and my mph gauge wobbles a lot and stays around 15 the whole time Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 12, 2020 Share Posted May 12, 2020 Possible there is something wrong in the speedo cable. Link to comment Share on other sites More sharing options...
AMC86Kid Posted May 12, 2020 Author Share Posted May 12, 2020 seems like the gas gauge works I'm gonna look up some good tachs that are simple to install let me know if you guys have any links to get a nice tach I'm looking for one that dosent have a super high rev limit number on it hopefully a max of 6k would be nice Link to comment Share on other sites More sharing options...
Eagle Posted May 12, 2020 Share Posted May 12, 2020 Mt red '88 MJ Chief has the "3/4" gauge cluster, with gauges but a large gas gauge instead of a tachometer. The previous owner had strapped a 2" Sun tach to the steering column. It worked, but it was too small for my liking -- I use the tachometer much more than I use the speedometer. I replaced the 2" with a 3.x" Sun Super tach. It looked a lot like this one -- and in fact may be the same thing under a different name: https://www.autozone.com/gauges-and-gauge-accessories/tachometer/equus-black-3-3-8in-tachometer-gauge/255933_0_0 Link to comment Share on other sites More sharing options...
AMC86Kid Posted May 13, 2020 Author Share Posted May 13, 2020 Ok so I bought a Equus Tach and I'm looking at the instructions it says to connect the signal wire from the tach to the negative wire of the coil so my question to you guys is which wire is that ? Link to comment Share on other sites More sharing options...
AMC86Kid Posted May 13, 2020 Author Share Posted May 13, 2020 Link to comment Share on other sites More sharing options...
AMC86Kid Posted May 13, 2020 Author Share Posted May 13, 2020 I called the 1-800 number on the box and the guy said that the negative terminal is the green wire with the white line on it I guess i will hook it up and see and see if it works Link to comment Share on other sites More sharing options...
AMC86Kid Posted May 13, 2020 Author Share Posted May 13, 2020 I’m also wondering about where those two wires go to, the thicker yellow wire must be positive and both wires come from the main electrical harness but where do they lead too ? Link to comment Share on other sites More sharing options...
AMC86Kid Posted May 13, 2020 Author Share Posted May 13, 2020 Does anyone know where the three leads behind the gas gauge are suppose to connect to ? Link to comment Share on other sites More sharing options...
AMC86Kid Posted May 13, 2020 Author Share Posted May 13, 2020 Figured it out with this video his gauge and fuel sending unit works and looks very similar to jeeps Link to comment Share on other sites More sharing options...
AMC86Kid Posted May 14, 2020 Author Share Posted May 14, 2020 So the two wires from the ignition coil feed into the main wire harness but does anyone know were they go too ? Link to comment Share on other sites More sharing options...
AMC86Kid Posted May 14, 2020 Author Share Posted May 14, 2020 Guess I will just rip the main wire harness apart and see where they go to Link to comment Share on other sites More sharing options...
